Clears the specified access list meters.
meter_name | Specifies the ACL meter to clear. |
any | Clear the meter applied to wildcard, including all VLANs and all ports. |
ports | Clear the meter applied to a specific port list. |
port_list | Specifies to clear the counters on these ports. |
vlan | Clear the meter applied to a specific VLAN. |
vlan_name | Specifies to clear the counters on the VLAN. |
N/A.
Use this command to clear the out-of-profile counters associated with the meter configuration.
The following example clears all the out-of-profile counters for the meters of the ACL on port 2:1:
clear access-list meter port 2:1
The following example clears the out-of-profile counters for the meter meter2 of the ACL on port 2:1:
clear access-list meter meter2 port 2:1
This command was first available in ExtremeXOS 11.1.
